2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-26T22:57:00+00:00
    I wonder what's going on here...
    So many speculations on what can be done or not. I strongly doubt that our SP2 are broke just because of a firmware update that cannot handle power states just properly.
    MS told us that they are working on fixing the issue. Any well, even though this should not happen, it happened.
    This does not alter the impression I have of my sp2 at all. It is still the best mobile pc I have ever had.
    I am using hibernation now with everything and I have no issues.
    There will be a fix, I am sure.
    And I am also convinced that most support people know not enough about the issue to make a proper advice... still some people post these things as if this was the only solution (like having a broke sp2 now and the need to take it back)...
    I would strongly advice to have some patience...
    Yes using hibernate instead of sleep is the temporary fix.  Though doing the listed potential fix did appear to get rid of the inaccurate battery indicator but not the self wake from sleep.
    2013-12-27T00:07:38+00:00
    As TheNewNormal, suggests please use patience.  Anyone who is experiencing issues should generate a battery config report.  I did this as another sage community member advised and the results were illuminating.  First of all, you are at least, able to have discernable facts in hand on the functioning of  your battery.  The report generated will give you your past three days activity.  With, lots and lots more data if you continue to scroll down the report.  Besides these facts, Windows popped in and asked me if I would participate in a one question survey.  I said yes, and the question just wanted to know if my question on the battery config report had been answered.
    So, in fact MS is monitoring the issue closely.  Patience.  Lots of Good luck to those severely affected.
