2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-26T21:34:47+00:00
    I wonder what's going on here...
    So many speculations on what can be done or not. I strongly doubt that our SP2 are broke just because of a firmware update that cannot handle power states just properly.
    MS told us that they are working on fixing the issue. Any well, even though this should not happen, it happened.
    This does not alter the impression I have of my sp2 at all. It is still the best mobile pc I have ever had.
    I am using hibernation now with everything and I have no issues.
    There will be a fix, I am sure.
    And I am also convinced that most support people know not enough about the issue to make a proper advice... still some people post these things as if this was the only solution (like having a broke sp2 now and the need to take it back)...
    I would strongly advice to have some patience...
    2013-12-26T22:45:57+00:00
    If only the firmware flashing team at Microsoft had taken your sage advice, we wouldn't be in this mess in the first place.
    FYI: It's the height of summer here, makes patience with an overheating device difficult.
