2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-26T17:57:20+00:00
    It appears that the Firmware update also make both the Refresh Your PC and the Reset Your PC not functional. I was on a Chat with MS Support as I was trying to do a Reset Your PC and it hung at 27%. Support  now says the ONLY option is to get a REPLACEMENT SURFACE PRO 2. This actually seems to be a case of poor testing prior to release and a VERY BAD CUSTOMER EXPERIENCE. Nice job SURFACE TEAM - NOT!
    2013-12-26T19:32:27+00:00
    Hm, there is no "Install Default Secure Boot".
    What did you do to see this option?
