2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-26T16:45:37+00:00
    The reality is that if you upgraded there is no fix. Even if you install the old firmware like I did, you'll never get your surface back to the way it was as it happened to me.
    The only fix is to try to get your device replaced, or wait. I'm waiting. The firmware update MSFT pushed out was quite large, and the rollback was really small. They probably didn't roll everything back, not sure why. Maybe it is not reversible. Maybe the damage was done and now they have to bring us back from some bizarre state to where we should be.
    How this made it past MSFT QA department is beyond me.
    2013-12-26T16:56:55+00:00
    I am just utterly confused.
    The absurdly complicated workarounds previously described I am simply not prepared to accept or attempt. I'm no longer even sure what state the device is actually in at present.
    What I NEED to know is whether proposed updates in the near future will override ALL previous Microsoft blundering and establish a stable device which functions as intended. When will this occur?
    And will someone FROM MICROSOFT please tell me why, when I chose to download and review updates before installing them I am now unable to first visit the knowledge base and see what the bl00dy updates actually do. Being able to identify update details AFTER INSTALLING THEM is no use at all, particularly if they have already blown the machine up.
    This mess is an absolute disgrace, even by the standard of previous MS ****-ups. And for a flagship product!
