2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-26T05:42:34+00:00
    The 10/24 firmware update installed itself on my Surface on 12/14, replacing (presumably) the 12/10 update. Hope it works as planned...
    I'm guessing this is the product of http://winsupersite.com/mobile-devices/microsoft-will-re-release-surface-pro-2-firmware-earlier-expected
    I can confirm that the 24/10/2013 update showed up for updates yesterday and installed on my sp2 with the December update.
    So far, no issues anymore.
    We will probably get a revised update in January.
    Merry Christmas to everyone (especially sp2 owners who can enjoy their gadget again 😁)
    2013-12-26T15:52:47+00:00
    So I just chatted with Support and this is what I got:
    Jack: You can just follow these steps though.
    Jack: 1. Turn off the Surface device.
    Jack: 2. Press and hold volume up rocker.
    Jack: 3. Press and release power button, then release the  volume up rocker. The UEFI Menu will display then.
    Jack: 4. Select Install Default Secure Boot, and tap Yes.
    Jack: 5. Exit Setup and tap Yes to confirm.
    According to Jack, this removes the Dec. 10 firmware.
    Jack: Technically, since we have remove the Dec 10 firmware update, at this time, we can just have to monitor the performance of your Surface.
    Jack: But rest assure that by doing the steps that we have done earlier will surely resolve your issue.
    Jack: Since Microsoft Engineers are already aware to Dec 10 firmware issue.
    Bradford: so what version firmware am I supposed to be on now? Oct 24?
    Jack: Basically, Microsoft is re-creating a latest firmware updates right now.
    Jack: But at this time, you just use the Oct firmware update. But no need to worry too much, you device will still be updated just by running Windows Updates.
    Jury's still out on whether this will work, I'll try to come back to this forum and update you all.  It might take me a couple of days, tho, Christmas Eve and all.
    Merry Christmas everybody! May our Surfaces have dreams of Sugar Plum Fairies, and may we owners finally settle our brains.
    So I tried this and can report back it works :)
    You must have the Oct update installed Microsoft pushed it out some days ago then follow these instructions.  I have been on battery all day and still have 90% left.  Sleep problems and false battery reporting is gone.  I close my type 2 cover and it works prior to dec fimware update.  I am a happy camper :)
    Just tried your steps, I'm crossing my fingers as all the other suggested workarounds have failed in my personal experience. Will report back in a couple of days.
    Thanks!
    Edit: this didn't work for me as the problems reappeared some hours later.
    Secure boot keys will not roll back the firmware.  This just reinstalls the default secure boot keys that were installed when Windows was installed on the device.
