2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-25T18:37:26+00:00
    Xmas day or not, there's an update available today.
    Unfortunately it no longer seems possible to see a kb reference number for the update so that I can check to see what it does. After the last few experiences I'm reluctant to install anything until I am reassured that it wont break the SP2 and require me to do system restore rollback as the last one did.
    Why no kb number for these updates as always in the past. I have to INSTALL before I can find out? Repeated attempts to find this information have defeated me.
    Roy
    2013-12-25T21:44:21+00:00
    So I just chatted with Support and this is what I got:
    Jack: You can just follow these steps though.
    Jack: 1. Turn off the Surface device.
    Jack: 2. Press and hold volume up rocker.
    Jack: 3. Press and release power button, then release the  volume up rocker. The UEFI Menu will display then.
    Jack: 4. Select Install Default Secure Boot, and tap Yes.
    Jack: 5. Exit Setup and tap Yes to confirm.
    According to Jack, this removes the Dec. 10 firmware.
    Jack: Technically, since we have remove the Dec 10 firmware update, at this time, we can just have to monitor the performance of your Surface.
    Jack: But rest assure that by doing the steps that we have done earlier will surely resolve your issue.
    Jack: Since Microsoft Engineers are already aware to Dec 10 firmware issue.
    Bradford: so what version firmware am I supposed to be on now? Oct 24?
    Jack: Basically, Microsoft is re-creating a latest firmware updates right now.
    Jack: But at this time, you just use the Oct firmware update. But no need to worry too much, you device will still be updated just by running Windows Updates.
    Jury's still out on whether this will work, I'll try to come back to this forum and update you all.  It might take me a couple of days, tho, Christmas Eve and all.
    Merry Christmas everybody! May our Surfaces have dreams of Sugar Plum Fairies, and may we owners finally settle our brains.
    So I tried this and can report back it works :)
    You must have the Oct update installed Microsoft pushed it out some days ago then follow these instructions.  I have been on battery all day and still have 90% left.  Sleep problems and false battery reporting is gone.  I close my type 2 cover and it works prior to dec fimware update.  I am a happy camper :)
