2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-24T13:13:40+00:00
    I agree.  The Microsoft response to this should have been almost immediate.
    I've had the issue of charging not showing correctly, and used the power + volume up reset technique to get it back.  I've changed all my power options to hibernate now, and that seems to have resolved the issue until a firmware fix comes along.  I had to change the individual power plan options as well as the 'change all plan' settings for power button and closing the lid (I have the type cover 2).  Everything is set to hibernate, so I have an extra few seconds to wait for the Surface to boot up, but battery levels are at the same level as when I leave it.
    I've had two hardware updates come through (24/10/13 updates), which have both installed correctly, but I was experiencing the charging issues after these updates were installed.  Since I've changed all settings to hibernate (without any way of the device only going to sleep), there haven't been any issues.  However, this isn't satisfactory, and I hope Microsoft come up with a fix very soon.  I have no intentions at this point of doing a restore of the device to see if that helps.
    I've checked the battery report and the device seems to be charging back to 100% ok.
    2013-12-24T13:16:02+00:00
    And BTW, a merry Christmas to all.  Tomorrow is probably not the day to bother tapping away at a keyboard, so this shouldn't bother us all too much.
    Eat, drink and be merry.
