2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-24T01:28:24+00:00
    Microsoft releasing a revised firmware update as soon as possible sounds good, but in addition they should recommend a safe strategy to use in the meantime.  My approach of always doing an explicit Shut Down seems to be doing fine and it may be as simple as that. In addition, Microsoft should make sure their support people know to advise people who think their Surface is bricked to try the two button restart while plugged in. A lot of people will be upset if a Christmas present or a vacation computer malfunctions, and Microsoft should do better than have clueless support personnel schedule Microsoft Store appointments in January or have people mail in their tablets for service.
    2013-12-24T12:29:41+00:00
    Besides having the battery drain issues during sleep mode since the update, my Surface now constantly shows that I have 100% battery even after prolonged usage. Also, my battery, when fully charged, is only 5:35 as opposed to the 7 hours Microsoft promises. I use the default battery settings, however, the battery drains rapidly although I am using the surface lightly and running small applications such as the browser. My questions are such; How can I make my battery last longer (or as long as it should) and why is my battery always full?
