2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-23T20:16:53+00:00
    After switching everything to hibernate I've not experienced any more of the fake 100% battery rescaling issues.
    I've gone all the way and avoided both sleep and hibernate.  I just switch off manually using Windows, and don't even depend on the hardware button except to start.  I've seen no waking up problems and no abnormal battery drain.  It may be the safest approach to take until Microsoft fixes the problem.
    If that is all we have to do for the next few weeks it is a bother, but a small bother.
    2013-12-23T22:55:23+00:00
