2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-23T19:53:30+00:00
    The screen brightness on my SPro2 is also subject to unpredictable variations for reasons that are not clear or reproduceable.
    Adjust the screen brightnesses in your Power plan to consistent levels. If you have widely varying levels for battery vs AC, or regular use brightness vs "dimmed" display brightness, and have disabled adaptive brightness (which I have done), brightness can appear to fluctuate wildly. For example, if your dimmed display brightness setting is actually higher than regular use, your screen will light up as your device starts to timeout
    2013-12-23T20:01:31+00:00
    I ran powercfg /batteryreport one more time and to my disappointment, the total charge capacity still dropping.... Keep in mind I did a full system reset and I was able to reinstall the October firmware via windows update. Prior to this update, my SP2 never did this. So whatever was that MSFT rolled back, it DID NOT roll back my surface to how it was before.....
    Just so it's clear, the battery capacity is not actually dropping, it's just the software that thinks it is. the powercfg /batteryreport thing is the only way to see the real state of charge of your battery. There won't be any significant diminished capacity to your battery unless you experience the overheating problems, so just divide the energy number by 42,000 to get an idea of how charged your battery actually is.
    After switching everything to hibernate I've not experienced any more of the fake 100% battery rescaling issues. However, you can always do the 15+15 shutdown that's been mentioned repeatedly in this thread to properly recalibrate the battery meter.
