2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-23T18:43:35+00:00
    This update problem is persistent and infuriating.
    Today (23 Dec) I attempted to install one priority update plus one optional  (settings: notify me and I chose when to install) and yet again the machine (Surface Pro2) hangs with "installing updates" looped - both from control panel dialog and when I try to shut down. Forced shutdown, rebooted, selected priority update only and it installs successfully.
    I had dreadful problems when I tried to install the update on 16th Dec. At one point I thought that the machine was dead. I don't even recall exactly how I worked my way out of it.
    Quite honestly this is yet another Microsoft disgrace. The update from Hotmail to Outlook.com was broken for about 6 months.
    SkyDrive on the Surface: WTF? If there's a way of sharing galleries from this version (as with Win7/64 and all othyer browser implementations) then I haven't managed to find it. And this is the raison'd'etre of SkyDrive for many users! Changing the look of applications between  different versions of the OS is one thing, but changing the core functionality??? Completely NUTS. Skype is also horribly implemented on the Surface.
    The screen brightness on my SPro2 is also subject to unpredictable variations for reasons that are not clear or reproduceable.
    I'm beginning to regret buying this premium  (ie over-) priced device. And Win 8.1, whilst not quite the disaster that Vista was, is pretty horrible.
    Why oh why did you make the left-hand shift key on the Type keyboard so tiny??? Absolutely infuriating to be constantly typing a "|".
    BUT AT LEAST FIX THE BL00DY UPDATE FUNCTION WILL YOU!
    2013-12-23T19:38:09+00:00
    We actually did exactly what you're describing but the Surface Pro 2 is still waking itself up and draining the battery. So, this fix doesn't seem to work for everyone.
    Just FYI.
    Joanna-
    Oh i see... very sorry to hear that darl. It must have been some combination of what I did because I reset mine more than a few times. Could you try something for me? Just do a full Reset (with the full HDD wipe) and leave it at that... fresh version of Windows, with nothing on top, don't worry about the missing drivers. Give it a few days of sleep/shutdown tests and see if it still wakes up. Thanks.
