2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-23T14:45:09+00:00
    The best fix is to replace sleep by hibernation everywhere in the power plan including the lid close and power button action. This will stop the undesired wakeups. The device wakes up from hibernation fast, and given that there is no  connected standby yet, this may be a better option overall, because while in hibernation, the device is off,  consuming 0 power.
    2013-12-23T17:13:58+00:00
    I have an Asus but I'm mad as **** I turned off every damn option to not update, googled to find every option to not update and here I have my computer stalled at updating 15% (don't turn off your computer). Screw you guys who can't let me make my own decisions with my own software, I remember in Windows 7 when any minor microsoft software installation and you would change the update settings. Just in case its not clear I want my computer to do what I tell it to when I tell it to, that is all. Oh and genius having people use the start button for I don't know how many years..and hey lets just get rid of it! No one actually wants to run programs or things like that.
