2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-23T13:27:26+00:00
    By resetting do you mean restoring it?
    So there is literally no way to get the device back to it's stock state to get rid of the most recent firmware update??
    Regards,
    Tom.
    Hi Newcomer, you've got some 30pages to sift through, so here's the the tip:
    1. Download Firmware and Drivers HERE and extract it to a USB drive.
    2. Reset Surface Pro 2.
    3. After first boot, Go to Device Manager and update your Firmware to the one you downloaded.
    4. Update all drivers too while you're at it.
    DONE! Enjoy your SP2 October Firmware edition. Be sure to disable all Windows update until the next stable release.
    2013-12-23T14:04:02+00:00
    We actually did exactly what you're describing but the Surface Pro 2 is still waking itself up and draining the battery. So, this fix doesn't seem to work for everyone.
    Just FYI.
    Joanna-
