2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-23T13:14:32+00:00
    resetting is simply reinstalling windows. firmware is a device specific thing which isn't touched by it.
    2013-12-23T13:23:43+00:00
    I ran powercfg /batteryreport one more time and to my disappointment, the total charge capacity still dropping.... Keep in mind I did a full system reset and I was able to reinstall the October firmware via windows update. Prior to this update, my SP2 never did this. So whatever was that MSFT rolled back, it DID NOT roll back my surface to how it was before.....
