2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-23T11:46:09+00:00
    Same 24th October 103kb hardware update which I installed successfully this morning is back.
    And it's back again. Three times in 2 days
    The weirdness continues...
    ...don't think I'll bother installing it a third time.
    Well it loves you, you see...
    This reminds me of a funny quote from an episode of Star Trek TNG
    "It doesn't like your science officer... But it DOES like YOU!!!"
    "It" refers to a parasite by the way.
    2013-12-23T13:01:37+00:00
    By resetting do you mean restoring it?
    So there is literally no way to get the device back to it's stock state to get rid of the most recent firmware update??
    Regards,
    Tom.
