2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-23T03:20:22+00:00
    Lastly, I checked for Firmware Driver updates for each component manually from within the control panel. I updated each component (if the system found the driver automatically). Now I have been able to charge to 100% and expect my issues to be fixed.
    2013-12-23T11:00:09+00:00
    Same 24th October 103kb hardware update which I installed successfully this morning is back.
    And it's back again. Three times in 2 days
    The weirdness continues...
    ...don't think I'll bother installing it a third time.
