2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-23T02:30:14+00:00
    Update, I checked the device manger, and had to restart the computer one more time for the update to be fully complete. When I restarted the SP2 it updated the computer and took a good minute or two, loaded windows just fine and seems to be running very smooth!
    2013-12-23T02:35:06+00:00
    The Firmware update -m 10/24 I just installed was just over 4 MB...
