2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-23T02:00:57+00:00
    After this update My battery drains down to nothing if I leave the keyboard attached.
    Do others also note a significant difference with the keyboard attached?  I hadn't figured that out, but now that you mention that, the day my battery drained unexpectedly the Surface was connected to the keyboard, and I usually don't use the keyboard.
    It would be good to have a list of dos and don't to get us over the next few weeks until Microsoft fixes this.  Ideally Microsoft should prepare such a guide, but if they don't, we should.
    Some things I'd make sure to include:
    1.  How this problem can drain power and put the Surface into a state in which you both need to charge it and do a two-button restart to get it working again.
    2.  The keyboard effect on power loss, assuming it is reproducible.
    3.  The importance of doing explicit shut-downs after each use.
    2013-12-23T02:18:43+00:00
    I was one of the unlucky few to get the bum update, just after I upgraded from my Surface Pro to the Surface Pro 2 (w/256 GB and 8 GB memory) for the extra battery life. The only issue I noticed was battery life less than I had expected (marginal improvement relative my SP1 running Win8.1) and, varying batter charge percentage and time remaining.
    I am in Sales and I am not an IT guy; but I have proven myself to be pretty resourceful. Here is what I did (since the update has been pulled) to rollback the firmware update:
    1. I opened the Control Panel from the Desktop
    2. I opened the device manager
    3. I selected and expanded the Firmware
    4. Selected each component, selected Driver at the top, and "rolled back" each driver (that I could)
    5. Restarted the Surface Pro 2
    6. Checked for Updates and installed the System Firmware update 10/24/13
    7. Restarted the SP2 and SP2 installed the update
    8. I wrote this post
    I will follow up and let you know if this fixed my issue.
