2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-22T23:14:20+00:00
    Just got another hardware drive update dated 2013/10/24 (only 103kb). Is microsoft trying to roll back our hardware drivers? or this is just a false update? should we install it?
    Same here i don't have a clue and till i do im doing nothing hehe
    I haven't been offered any firmware updates since the 10 December one, which had reported its installation as failed.
    I have once been offered the update dated 2013/10/24 on the previous SP2 (can't remember what size), but i ignored it.
    2013-12-23T00:11:58+00:00
    Two failed updates is not inspiring confidence in me.  This is my first Microsoft tablet and it was not inexpensive.  I've not had any problems with my Android tablets at all.  After this update My battery drains down to nothing if I leave the keyboard attached.  Fail on Microsofts part
