2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-22T20:26:37+00:00
    ... Thank you Microsoft! It's summer in Australia, 41degrees and far beyond your SP2's operating temperature specs, your machines won't sleep nor stayed shutdown.
    My Favorite: (from the Nokia 1520 Windows Phone manual)
    "Always keep the battery between 15°C and 25°C (59°F and 77°F) for optimal performance. Extreme temperatures reduce the capacity and lifetime of the battery. A device with a hot or cold battery may not work temporarily."
    Probably seems like eminently practical advice if you design and build phones in Finland! Yes, seriously, there are the limitations of existing technology that will impact any Li-ion device you use. But one wonders if in Microsoft HQ that they don't need a big dose of reality that we are not all living in climate-controlled splendor 24x7 these days and design their devices to safeguard themselves and advise the user accordingly. There is no built-in system for monitoring and alerting you to internal temperature, whereas in Android you can monitor battery temperature and get apps that sound annoyingly loud and persistent alarms if your threshold limits are exceeded.
    2013-12-22T23:04:38+00:00
    Just got another hardware drive update dated 2013/10/24 (only 103kb). Is microsoft trying to roll back our hardware drivers? or this is just a false update? should we install it?
    Same here i don't have a clue and till i do im doing nothing hehe
    I haven't been offered any firmware updates since the 10 December one, which had reported its installation as failed.
