2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-22T13:22:22+00:00
    Just got another hardware drive update dated 2013/10/24 (only 103kb). Is microsoft trying to roll back our hardware drivers? or this is just a false update? should we install it?
    Same here i don't have a clue and till i do im doing nothing hehe
    2013-12-22T18:32:49+00:00
    This issues seems to have rendered my Surface Pro 2 useless.  I am finding that the date has been fixed permanently to December 18th and any attempts to power the system off don't work.
    I've been trying to get through to the Support desk for Surface at Microsoft and cannot connect to it at https://support.microsoft.com/ContactUs when I select the Surface it goes to a blank IE screen and get a blinking MS logo on the tab.  Other sites like Office seem to work fine so it is strictly the Surface desk that is unavailable.
