2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-22T10:53:57+00:00
    Phra Mick Ratanapanyo:
    Do you have a sd card? Remove it and see if the error occurs again.
    The waking problems are fixed now... New unit with all updates disabled and all drivers refreshed using the MS_October_Firmware_Driver Pack downloaded from the MS website HERE. The problems I face now with leaving the SanDisk Ultra 64gb MicroSD card plugged in are:
    1. Upon booting up from a shutdown-state... the screen brightness is set to 100%.
       Solution: Hotkey Fn+Backspace on Type Cover 2 adjusts brightness.
    1. Upon booting up from a shutdown-state... the Client Server Runtime (csrss.exe) is stuck in high gears consuming high CPU.
        Solution: Put the unit to sleep and then wake it back up.
    These problems don't occur if the SD card isn't inserted. I could eject the card everytime just before a fresh boot then shove it back in after but it's very annoying. Plus it'll hut under my finger nails and destroy the damn card slot in the process. According the the MS' October Troubleshooting Forum, the Oct Firmware had conflicts between the Audio and the SD card slot drivers. I hope these all get fixed in the up-coming Firmware Update.
    2013-12-22T11:13:18+00:00
    I now make a point of leaving SP2 plugged in overnight so when it wakes in night It is killing my battery, I realise this is not practical for all but has avoided a near flat battery for me come the morning! I hope Microsoft fix this soon.
    Find a MIDI self executable file and place its link inside the Startup folder. 'C:\Users\USER_NAME\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup'
    1. Once shutdown... If and when the unit wakes, it'll play that high pitched annoying sound. A good way to deprive yourself of sleep and curse Microsoft in the middle of the night.
    2. Play the MIDI file before closing the Type Cover so when it wakes up you'll know. In the meantime... Thank you Microsoft! It's summer in Australia, 41degrees and far beyond your SP2's operating temperature specs, your machines won't sleep nor stayed shutdown.
