2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-11T05:01:52+00:00
    Several similar looking issues (including the failed firmware update). Though 26 out of 34 updates installed ok.
    Pro 2 512.
    2013-12-11T05:05:25+00:00
    I religiously applied the Patch Tuesday Updates from December 10, 2013.  However, Windows Update says the firmware update failed with error code "WindowsUpdate_80070490 OR WindowsUpdate_dt000". Now when I close my Type Cover 2 Lid or SLEEP comes on from a Timeout, my Surface Pro 2 shuts down rather than sleeps.  Also, apparently I've never heard my Surface Pro 2 fans before.  During the shutdown process, they now come on with a big burst (might be a good idea in case the Surface is folded up and bagged immediately upon shutdown without a chance to cool by connective air flow through the vents).
    Thanks to anyone to let me know what I can do to properly install the 12/10/13 firmware update. Rather than have Microsoft determine what it thinks my Surface Pro 2 should do, I'd like options to control whether my Surface shuts down completely turning SLEEP mode and whether the fans come on.  For example, I'm willing to leave my Surface upright as long as needed to cool.  I don't want to wear out the POWER button awaking my Surface from shutdown or have the fans wear out just because Microsoft wants a cooling burst when I never let my Surface run hot or bag it right away.  The Power button and the fans are irreplaceable and I don't want to wear out my $1400 investment just because Microsoft is playing it safe on cooling and thinks we should buy a new Surface every few years, anyway.
    I am having the same problem. I called tech support and used the chat agent and both said that even though windows said it failed that it probably installed everything. I don't believe it that it is true for all things because my type cover drivers numbers do not match the driver versions that were released today. However, the Intel drivers do. So partial completion?
