2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-22T10:25:56+00:00
    I now make a point of leaving SP2 plugged in overnight so when it wakes in night It is killing my battery, I realise this is not practical for all but has avoided a near flat battery for me come the morning! I hope Microsoft fix this soon.
    2013-12-22T10:43:42+00:00
    Same 24th October 103kb hardware update which I installed successfully this morning is back.
