2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-22T07:05:33+00:00
    "Night of the Waking Surface"
    Had you manually shut it down using a Shut Down command?
    90% sure that I did. It was late at night, so hard to be 100% sure, but it's what I always do at night (I treat this as a laptop more than a tablet).
    I do this from settings > power > shutdown, rather than rightclicking the start button. It is possible I hit 'sleep' by mistake (didn't think of that until just now) but it should have been hibernating if that were the case.
    FYI: I'm in Australia, if that's at all relevant
    Had same problems with my previous SP2, waking up in the middle of the nights after being shutdown... AMC Walking Dead's zombies put to shame. I'm in Australia too.
    2013-12-22T10:20:25+00:00
    Phra Mick Ratanapanyo:
    Do you have a sd card? Remove it and see if the error occurs again.
