2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-22T02:32:29+00:00
    Actually turns out that it had just changed to hibernating whenever the button was pressed instead of sleeping though it still said sleep. Changing it away from and back to sleep messed things up again :(
    2013-12-22T03:39:32+00:00
    Just got another hardware drive update dated 2013/10/24 (only 103kb). Is microsoft trying to roll back our hardware drivers? or this is just a false update? should we install it?
