2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-22T01:24:46+00:00
    Just had my first "Night of the Waking Surface" : I had shut it down and left on power. In morning opened cover and screen was on (either instantly from sleep, or was already on). No heat issues thankfully.
    Had you manually shut it down using a Shut Down command?  If so, it is indeed creepy.
    Hopefully we'll get beyond this soon.  Microsoft has been deficient in not educating all of its support personnel about this and not giving them instructions to give out that keep this problem manageable.  The community is doing that, but Microsoft could do better and also project a better image.  They should have a web page devoted to this issue and make sure it is well publicized.  Hiding until after Christmas is not a good approach.
    2013-12-22T01:52:44+00:00
    90% sure that I did. It was late at night, so hard to be 100% sure, but it's what I always do at night (I treat this as a laptop more than a tablet).
    I do this from settings > power > shutdown, rather than rightclicking the start button. It is possible I hit 'sleep' by mistake (didn't think of that until just now) but it should have been hibernating if that were the case.
    FYI: I'm in Australia, if that's at all relevant
