2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-21T20:10:50+00:00
    My surface won't even turn on now.  What am I supposed to do?  Bought it for my wife for Christmas and already want to get rid of it for a tablet that will actually work.
    Try getting the computer to restart by connecting to the charger and using the two-button method described at http://www.microsoft.com/surface/en-us/support/warranty-service-and-recovery/surface-pro-wont-turn-on#shutdown
    It worked for me.  Since then, I've been keeping the computer well charged and shutting down manually each time.
    It is a bother, but it works so far, and it sounds like there will be a re-do on the firmware update in January.
    Microsoft should put out a detailed statement of advice on dealing with this, and they should make sure their support people know about this problem.  In the meantime, Merry Christmas from the user community.  We'll do what we can to get this to work.  The Surface is the sort of product you want working over the holidays.
    2013-12-21T22:39:33+00:00
    Just had my first "Night of the Waking Surface" : I had shut it down and left on power. In morning opened cover and screen was on (either instantly from sleep, or was already on). No heat issues thankfully.
    Checked windows update and a small 24th October hardware update had appeared (coincidental timing).
    Battery fully charged, well as charged as it gets these days, 41,040 is my maximum after this fiasco.
