2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-21T19:33:51+00:00
    Josh,
    Thank you,
    Tim
    Since Microsoft is no longer putting out quality patches I have set my SP 2 Pro to only notify.  I will give them a couple of days then check the forums before upgrading.
    If I did something like this to my clients I would be walking down the road talking to myself.
    Missed Tim's earlier post, but I have to say that I find it inexcusable that QA did not find this issue.  And "small number?"  I don't think so.
    2013-12-21T20:07:57+00:00
    Thanks for this; I had previously tried steps 1-3 without success, so skipped straight to uninstalling the battery. Didn't bother with letting it sit for 15 mins, but so far it seems to have fixed the waking up problem for me; at least, over this afternoon it has successfully hibernated after sleeping for an hour 3 times. Also, installing the latest Win8.1 x64 HD4400 driver from Intel seems to have fixed (at least mostly) the weird colour issues with the screen. Although I had to uninstall it and reinstall with device manager as the installer exe refused to run.
