2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-21T18:35:11+00:00
    Hi
    I'm, having the same issue, but as I'm not a specialist,
    so when you say "**have taken steps to remove the update for Surface Pro 2"**could you please give some details on the procedure...
    I would not like to perfrom a wrong manipulation and make the problem worst
    regards
    Laurent
    Laurent, what are you referring to?  Try the update that I did above, which in effect remove the update. I don't know that there is a simple way to remove the update.
    I removed the update and seems to be working just fine.
    2013-12-21T19:19:58+00:00
    Josh,
    Thank you,
    Tim
    Since Microsoft is no longer putting out quality patches I have set my SP 2 Pro to only notify.  I will give them a couple of days then check the forums before upgrading.
    If I did something like this to my clients I would be walking down the road talking to myself.
