2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-21T07:57:56+00:00
    Josh,
    We are working through the holidays to deliver a fix...
    If there were an official announcement, where would I find it; or don't Microsoft do that?
    The only channel of information I've found so far is to keep maniacally checking this 270 post thread and windows update.
    Cheers
    2013-12-21T11:42:31+00:00
    Matthew,
    thanks again,  I followed your lead,  kind of:
    instead of reinstalling all of the updates,  I did the following:
    1. went into device manager  and rolled back all 3 firmware drivers,
    2. performed a reboot and the middle firmware driver did not startup properly so I did a second reboot.
    3. verified that I have the firmware drivers from October installed now
    3. then uninstalled the battery drivers,
    1. shut it down,
    2. and then did the up volume/power button reset
    3. let it sit for 15 minutes
    7. restarted it.
    so far,  I have gone over 4 hours without a wakeup or battery issue,  and have gone from 100% to 95%.
    back to normal.
    Lowell
    Your recipe seems to work. Thanks!
