2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-21T06:56:00+00:00
    Matthew,
    do you happen to have a list of drivers to update?
    Lowell
    Hi Lowell
    I updated these, and the "telemetry driver" showed up as UNKNOWN device, then it found a better driver when I told it to search the folder on the desktop.
    Hope it helps!
    This is the best fix ever! Thanks Matthews. :)
    Rolling back to October Firmware, when booting up from a shutdown state with SD card inserted I'm met with two problems:
    1. Screen brightness being set to 100%
    2. The Client Server Runtime (csrss.exe) hogs CPU causing the system to lag. Solution: putting the system to sleep and wake back up fixes this issue temporarily until the next boot up from shutdown state.
    Does anyone else have these problems?
    Note:
    1. I've updated all devices in the Device Manager to the October2013SurfacePro2 Firmware Driver Pack.
    2. I'm using a SanDisk Ultra 64GB MicroSD XC1 Class 10
    2013-12-21T07:40:51+00:00
    My 256 Gb SP2 is working fine (lucky me). But here's something from my experience with my Surface RT that might help. MS Support said the RT in Sleep mode can sometimes lock up in a Hibernate mode. For the RT, if you hold the Power button down for about 5 seconds, the machine will completely shut down. Then a single short press of about 1 second will turn it on as usual. Hope it works for you (I always shut down my SP2 if I am not using it for more than ~1/2 hour).
    I'm now experiencing a problem where sometimes after leaving in sleep mode awhile, I go to turn it on to discover it actually shut down. I think it has something to do with plugging in the AC adaptor. Anyone else have this sort of issue? It's almost hard to tell when it's waking up verses turning starting back up since it's so fast, but what gave it away was that the uptime in the task manager reset.
    Yep- same here, it's a nightmare....
