2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-11T04:45:05+00:00
    The latest firmware update appeared to work successfully on my Surface RT, but shows in the Update History as 'Failed' with error code 80240FFF.
    This is almost identical symptom to that on my Pro 2, except that one has a different error code. (see http://answers.microsoft.com/en-us/surface/forum/surfpro2-surfupdate/system-firmware-update-121013-fails-to-install/b2163f4b-9019-4508-a931-45c44fbbeb9c?page=1 )
    2013-12-11T04:45:26+00:00
    Same issue. Pro 2 256.
