2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-21T05:11:05+00:00
    Yes, I know firmware is basically like BIOS, I was responding to the post by MS moderator to point them into thinking in this direction.  The MS "firmware" update packages include updates to system firmware and drivers. The system restore in windows 7 and 8 can undo the undesired driver updates. But it may be unable to undo the firmware updates, so I was thinking a quick fix would be to release a program to allow users to revert to the previously installed (an backed up) firmware.  MS may even post firmware binaries online, so that people who have problems could get them and revert theit broken systems.
    In the end all of these may result in much lower warranty return rates for MS.
    2013-12-21T06:40:28+00:00
    Matthew,
    thanks again,  I followed your lead,  kind of:
    instead of reinstalling all of the updates,  I did the following:
    1. went into device manager  and rolled back all 3 firmware drivers,
    2. performed a reboot and the middle firmware driver did not startup properly so I did a second reboot.
    3. verified that I have the firmware drivers from October installed now
    3. then uninstalled the battery drivers,
    1. shut it down,
    2. and then did the up volume/power button reset
    3. let it sit for 15 minutes
    7. restarted it.
    so far,  I have gone over 4 hours without a wakeup or battery issue,  and have gone from 100% to 95%.
    back to normal.
    Lowell
    can you please list the drivers you used with a download link?
    Thank you!
