2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-20T13:30:00+00:00
    I was not aware of the issue everyone was having.  When I got the "Battery at 5%; Plugged in but Not Charging" message I went to MS online support.  They said that they needed to replace the hardware.
    They shipped me a replacement in two days.  I have not booted it up yet, but I wonder if the firmware update is already installed.
    Fortunately my Surface Pro 2 started working again the next day and has been fine till yesterday.  Now my battery indicator shows that it is low, but it still keeps working.
    2013-12-20T16:36:44+00:00
    I have found that changing the SP2 power settings from sleep to hibernate has solved the issue of it waking all on it's own.
    Under the power savings menu, then under "sleep" I changed the settings in the pulldown menu to hibernate after 10 minutes, and moved up sleep to 15 minutes. So it would hibernate first.
    Then under the " what happens when pressing the power button" settings I changes that to hibernate.
    It takes and extra second to boot, but no big deal.
    Ben
