2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-20T12:17:39+00:00
    matthew,  did this also fix the waking from sleep issues?
    BTW,  I have been experiencing the waking from sleep since installing the 12/10 firmware update.  I have tried all the fixes except for a complete reset as I really do not want to go thru the hassle of reinstalling numerous programs again.
    I have a 128GB surface 2 pro
    2013-12-20T13:24:23+00:00
    I've now gotten the computer to restart using the two-button method described at http://www.microsoft.com/surface/en-us/support/warranty-service-and-recovery/surface-pro-wont-turn-on#shutdown
    The battery indicator is very low.  If it charges, I'm OK for now.  If it doesn't charge, it is unusable.
    The computer is charging, so I may be OK for now.
    But I have a question about firmware updates.  If I have a system backup to an external hard drive that I made a few days before the firmware update, does restoring from that update undo the effects of the firmware update?  Or does the firmware update make other changes such as to the BIOS that can only be fixed by a new firmware update?
