2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-11T04:12:52+00:00
    Yep, exact same issue... can't seem to update again either.
    2013-12-11T04:33:54+00:00
    I have same issue on my Pro2 256GB machine.
    And also getting similar symptoms with the latest firmware update on my Surface RT, except different error code (80240FFF)
