2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-20T04:28:48+00:00
    Maybe folks should say what continent they are on.  It seems like many of the people having the worst problems are in Australia.  I'm in the USA and although I check Windows Update several times a day, I've never received a rollback to anything on 24/10/2013 and the fact that most people use this date format when talking about it leads me to guess that the update being issued outside the USA. (or the state of your machine determines whether you see the update)  I had the failed 12/10/2013 update and the next day or so I got a "system hardware update" on 12/11/13, dated 12/10/13.  Kinda hard to look back in time because the Disk Cleanup recommended by Dylan Tullberg erased my Windows Update history.
    Also in bagging and after bagging my Surface Pro 2, I realize I never thought very much about where I grad the case.  Aside from horrifying problems like the ones described in this forum, it seems it's very easy to turn on/wake the device by being careless about how you grab it.  Having the thing on and in a bag is a recipe for a positive feedback loop.   So in future versions, maybe (aside from the problem here), maybe Microsoft should give more thought to the Power button design and make it less easy to accidentally turn on.  I've done that both with my SP2 and my RT device upon occasion.
    2013-12-20T04:40:43+00:00
    Wow, this thread really explains why my battery meter keeps jumping up and down and all over the place. I can't even trust it to tell me the real amount of battery life that is left.
    The overcharging stories are seriously scary. If not just damaging your battery, they could start a fire and cause the battery to burst. In my case, thankfully, all I'm observing is the battery meter that decides the current charge level is always 100% after waking up, and produces proportionally shorter apparent battery life (but at least the battery report shows the real state of charge.) I followed the previous advice to go with hibernation instead of sleep for now and it seems to be working.
    P.S. Massive pile of refurbished Surface Pro 2's incoming...should help with that supply/demand imbalance we all worked so hard to get around, right?
