2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-20T03:42:14+00:00
    I'm guessing the failed update's impact was gradual but wide spread. Fixes may appear to work at a glance, but you won't know until after a few days of testing. I have a wake-tester, self-executable midi music file which plays at the start up to let me know if the system awakes by itself. My recommendation is, if you COULD exchange your tablet for a new one, don't wait, do it asap. Disable all updates from **** and be happy.
    2013-12-20T03:55:01+00:00
    My Surface Pro 2, whicn I bought from Harvey Norman, Adelaide, is being replaced , but no stock in Adelaide. They hope to get me a replacement from their Mount Gambier store next week.
    No updates will be applied to the replacement until I hear that Microsoft have fixed the problem !!!
