2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-20T01:55:22+00:00
    To ensure the best experience for our customers during the holiday season, we have taken steps to remove the update for Surface Pro 2 that was previously published through Windows Update on December 10^th^, 2013. We are working to release an alternative update package after the holidays.
    Josh
    How do you define best customer experience? those that have updated like me should not deserve the holiday and have a brick surface that couldn't charge?
    And at the same time your great employees enjoying the holiday, we as your customers, consumers are deserved to be delayed in getting the fixes?
    2013-12-20T03:15:21+00:00
    I just purchased a Surface Pro 2 256GB model, and am having some trouble with the sleep functionality. Over the course of around a day I've had the device lock up several times after putting it to sleep and waking it via the power button (I have to do a hard reset to get it working again). I doesn't look like I got the bad update that was mentioned (I set it up yesterday). Is this the same issue that anyone else is happening? I'm not sure if the product is defective or not, and really didn't want to return it since it's basically sold out everywhere, and I won't be around again to purchase a new one after the holidays.
    Thanks for any info!
    I installed the firmware update the day it came out and the only problem I noticed initially was that it would sleep when inactive even though it was set to shut down when inactive.
    Today I tired to boot using the start button and the computer hung.  I shut it down by holding down the start button and then it restarted fine and seemed normal but then just shut off suddenly while I was using an app.  Ever since then it won't start, even though I've had it connected to the charger for 20 minutes.
    I haven't seen any overheating problems.
    I called my local Microsoft store and the pressed the button to speak to a representative.  It was answered by one of the national support people who suggested I make a service appointment.  I asked him whether he'd heard about the firmware update and he said no.  It sounded like the guy was clueless rather than deceptive.
    The scary part is that everything was pretty much OK for a week and then failed., so this may happen to more people.  And in the meantime I don't have a computer and the readings on how Microsoft will handle this don't look very encouraging.
