2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-19T22:23:16+00:00
    Update to my earlier post.
    I eventually got to reset again - the system ran through to Resetting -98% before the screen blanked and it restarted. But apart from the message at the bottom of the recovery bluescreen changing to:—
    Press the Windows key for UEFI Firmware settings
    nothing has improved, and I now can't get out of the error bluescreen/BIOS loop.
    I eventually got out of the loop, and the unit fired up, seemed to be working OK. Went to Windows update, and there were 23 updates available, including the System Firmware Update - 24/10/2013  28.9 MB.
    Decided I'd un-check that update, and install the rest, they downloaded, but when all had downloaded, the unit reverted back to the screen that stated (et al.)  that updates had never been installed.
    I then allowed it to download and install all those updates. After the restart the screen showed the (increasing %) message about the updates for some time, then the unit turned off. On powering up I was back to the revolving door. After several hard resets, it got back to the updating screen, at 68%. Finished that, and seemed to be working. So I shut it down, and went to bed.
    This morning it was back in the bluescreen/BIOS loop.  After several power cycles I was able to get to the refresh/reset screen, ran a refresh, and now it is back to "use a different operating system"
    2013-12-19T23:17:33+00:00
    Unfortunately too many people have this update already before it went down.
    I have a feeling just the indicator is wrong, not the charging itself, because when it says 10% charged I can go on for hours and it still remains on 10%.
    I have my surface 2 weeks now and half of my charges had this issue.
    What I do to fix the battery indicator is shut my surface off for at least 15 minutes. It doesn't matter if the charger is still plugged in. Of course this is a temporary fix until the next charge.
