2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-19T21:30:46+00:00
    What's frustrating is my company, around 500 employees develops and maintains its own software for our CRM, our dialer software, our everything, many many products. When something goes wrong, be it a small release or a wide release, we sit someone in a seat on their ****, and have them fix it.
    This pertains to 4 models of product, the Surface Pro 2 64G, 128G, 256G, and 512G. That isn't a wide range or products that needs to be targeted. They all have IDENTICAL hardware, just larger ssd's. So I really really hope MS is sitting their Devs on their asses in a chair, creating a patch to roll us back to the previous Firmware which, by all accounts was at least working. I cannot imagine, they couldn't do this in a matter of a day or two to come up with an Alpha, test, beta, test, beta 2, then RC that out to us. Even if they don't provide it into the update cycle, release a temp tool to help us out. I mean really, this is frustrating.
    Mario
    2013-12-19T21:59:08+00:00
    My 256 Gb SP2 is working fine (lucky me). But here's something from my experience with my Surface RT that might help. MS Support said the RT in Sleep mode can sometimes lock up in a Hibernate mode. For the RT, if you hold the Power button down for about 5 seconds, the machine will completely shut down. Then a single short press of about 1 second will turn it on as usual. Hope it works for you (I always shut down my SP2 if I am not using it for more than ~1/2 hour).
