2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-19T20:57:45+00:00
    I installed the System Hardware Update 24/10/2013 yesterday. It does not fix anything. My device slept fine overnight. I shut it down this morning. It was hot when I came into work and the battery was at 50%. I changed my power button and close lid to power off. I checked it two hours later and it was warm. I booted it up and the battery was at 5%. This means that it will wake up even when it is powered completely off......
    I would rather not wipe my entire system to fix this. I just installed a lot of programs, plus activated my Office 2013 Pro. They should have a temporary fix that will remove the affected files and reinstall the old firmware. I want to use my device while I travel over the holidays without it being plugged in or worrying about if it will power on.
    I checked to see if I had a restore point, but there wasn't any. I wish I would have created one. It is annoying about these firmware updates. I could even install the October one. I was the small category where the touch cover telemetry was messed up after. It sounds like Microsoft has a validation problem. Please test things before you release them.....
    It's interesting because my company fixed a bug recently -- in just days -- that was caused NOT BY US but by an Android ROM update.  We were told -- "We don't care if it is your fault or not.  If you claim to be an enterprise company you will respond and fix this."
    Microsoft, are you getting the message?????
    2013-12-19T21:22:02+00:00
    I had issues with the battery not charging at all - it was stuck at 0% not charging all day today after the update was installed yesterday.  Disconnect the power and Surface Pro 2 immediately hibernated maintain my work but would only work with power connected.  Mine seems to be behaving correctly now after running through the following steps.
    1. Download and extract the October Update pack from MS Download
    2. Device Manager - expand the firmware section and double click each of the firmware entries, click the driver tab and roll back the driver
    3. Then I rebooted
    4. Each of the 4 firmware entries I then chose to update the drivers but manually point to the Microsoft folder in the extracted update pack
    5. 3 updated to a newer driver dated between September and November and one remains labelled as Firmware Resource and a driver from June 2006
    6. Rebooted again and saw the problem still remained
    7. Then do a full shutdown using WIN+X > Shutdown or sign out > Shut Down
    8. Left it off for a few minutes with the charger connected and at the next boot my battery reported 100%
    9. Disconnected the power and after 30 minutes the battery meter reported a drop of about 5%
    10. Have used it on and off power throughout the day and the battery meter appears to be behaving correctly reporting charging and discharging at what seem to be normal rates
    I am unsure if the rollback and full shutdown fixed it or if the full shutdown alone simply fixed it.  It isn't rolling back the firmware as I am led to believe it is an update of the physical hardware that cannot be rolled back and also an updated driver the works alongside it from within Windows (the one found in Device Manager) - I may be wrong though so I will be glad to be corrected on that one if anyone knows any differently.
    This is what worked for me today so it is worth a try if Microsoft are not releasing an update to correct the issue before Christmas as seems to be indication from many sources.
    Hope it manages to help some of you out.
