2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-19T20:46:09+00:00
    I am typing this on my fully functional I-phone because I can no longer boot up my $1500 surface pro 2. This is due to a dead battery I can no longer charge (thought I was charging it). I have all of microsofts updates and the associated "features" that come with them. Pretty difficult to sell friends and family that Microsoft can make an iPad killer when I can't turn it on.
    Even when the update comes out, it should prove difficult to update the firmware without the ability to turn it on now. What do you suggest we do next ?
    Frustrated and buried in snow,
    Chris
    2013-12-19T20:52:44+00:00
    I installed the System Hardware Update 24/10/2013 yesterday. It does not fix anything. My device slept fine overnight. I shut it down this morning. It was hot when I came into work and the battery was at 50%. I changed my power button and close lid to power off. I checked it two hours later and it was warm. I booted it up and the battery was at 5%. This means that it will wake up even when it is powered completely off......
    I would rather not wipe my entire system to fix this. I just installed a lot of programs, plus activated my Office 2013 Pro. They should have a temporary fix that will remove the affected files and reinstall the old firmware. I want to use my device while I travel over the holidays without it being plugged in or worrying about if it will power on.
    I checked to see if I had a restore point, but there wasn't any. I wish I would have created one. It is annoying about these firmware updates. I could even install the October one. I was the small category where the touch cover telemetry was messed up after. It sounds like Microsoft has a validation problem. Please test things before you release them.....
