2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
  1. Deleted
    2013-12-19T19:16:42+00:00
    I just purchased a Surface Pro 2 256GB model, and am having some trouble with the sleep functionality. Over the course of around a day I've had the device lock up several times after putting it to sleep and waking it via the power button (I have to do a hard reset to get it working again). I doesn't look like I got the bad update that was mentioned (I set it up yesterday). Is this the same issue that anyone else is happening? I'm not sure if the product is defective or not, and really didn't want to return it since it's basically sold out everywhere, and I won't be around again to purchase a new one after the holidays.
    Thanks for any info!
