2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-19T18:52:01+00:00
    This firmware debacle would explain why I found my Surface 2 on the charger last week in a rolling boot (wouldn't make it past the Surface splash) and why they were so quick to get a new one in my hands without placing a hold on my card for the advanced replacement.
    2013-12-19T18:57:35+00:00
    I have a System Hardware Update 24/10/2013 205KB being presented to me by Windows update - it appeared about 7 hrs ago.  Although after having read the post here of someone who did  install it I've left it alone.
    I installed this - not noticed any improvement - seems to now sleep & resume okay but not hibinating. Hells bells, hope this is fixed soon - I'm gutted - could have used the money for something that works !
