2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-19T16:40:49+00:00
    I have a System Hardware Update 24/10/2013 205KB being presented to me by Windows update - it appeared about 7 hrs ago.  Although after having read the post here of someone who did  install it I've left it alone.
    2013-12-19T18:17:04+00:00
    I too can confirm that the Hardware Update from October appeared on Windows Update, having read the post about multiple problems following installation, I decided to go ahead and install it. I am writing this comment on my Surface Pro 2, so no blue screens of death appeared and nothing weird happened. Although is still too early to tell if it fixed the battery issues. Will follow up in a couple of hours.
    Edit: this didn't seem to fix the issues with the battery level, still gets reseted to 100% after waking up. Haven't noticed any battery drain though.
