2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-19T16:31:48+00:00
    I can report that Microsoft are reinstalling the original firmware dated 24/10/2013. I just received it through windows update.
    I don't see this.
    2013-12-19T16:37:49+00:00
    How did you download the October firmware?
    It came via windows update after I reinstalled the OS via the recovery option. Some people have noticed that cleaning up temp system files using the disc cleanup utility can make certain updates show up again if you select "windows updates" in the dialog. Maybe give that a shot or wait longer to see if it shows up for you.
