2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-19T15:56:01+00:00
    I see the same problem even after resetting windows to the default factory image. I download the October firmware update which seems to have replaced the December update.
    However my surface now runs hot. Even just sitting on the dock it would barely get hot. Now it is hot to the touch, even the LCD feels hot. I'm worried because the fans are not kicking in. I think I'm just going to turn it off and essentially have a $1200 brick.
    I can't say for sure but it is almost as if the device is over charging....
    I have unplugged it from the dock station and are letting it cool off to prevent battery damage.
    2013-12-19T16:22:52+00:00
    How did you download the October firmware?
