2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-19T11:24:43+00:00
    Update to my earlier post.
    I eventually got to reset again - the system ran through to Resetting -98% before the screen blanked and it restarted. But apart from the message at the bottom of the recovery bluescreen changing to:—
    Press the Windows key for UEFI Firmware settings
    nothing has improved, and I now can't get out of the error bluescreen/BIOS loop.
    2013-12-19T13:35:21+00:00
    True, but it does appear to temporarily allow the battery meter to reset, which if your SP2 was stuck at 5%, means you can finally unplug it and use it as, you know, a tablet.  The reset worked for me in that my battery finally showed as 100%.
    I have to make a quick correction - my battery meter is working again.  I thought it wasn't charging, but it just jumped from 57 to 77 percent. I didn't see an alternative firmware download or update, but maybe they did it transparently?
    Either way, excellent.
